If you use foil it works.... but.....upon removal of said foil ALL the info is then transmitted from the time when covered..........then Gotchya
If you use foil it works.... but.....upon removal of said foil ALL the info is then transmitted from the time when covered..........then Gotchya![]()
A static discharge gun works very well too, give it a high voltage shock & block the bejeezaz out of it leaving no evidence.
Then you just happen to have a van that blows them up, sooner or later it wont be replaced![]()
Well if certain vans, belong to certain characters, persistently have issues with the GPS module, when other vans/employees don't, and neither do 99.9% of those particular units, then at a guess a manager would be likely to be suspicious.
Been with a trackered van, my mate tracking, 2 yrs ago, cost 20p to enquire where the vehicle was
must be easy/cheap with a large fleet?
