I'm glad i found this web site. Some of the information on other posts has been really helpful thanks.
I'm installing underfloor heating wires on warmup insulation boards. tiling with 30 x 60 porcelain tiles directly on top.
The instructions for the thermostat advise to cut a channel in the insulation boards to insert the temperature sensor probe. i am advised to check the resistance, and it should be between 8 and 12 ohms, at 20 - 30 degrees. The room is fairly cold, I would guess about 15 degrees. Trouble is the resistance is comming out at 15 ohms.
Does anyone know if this is going to be a problem?
Thanks.
Thanks.
