Hi
I've got a boilermate II powered by a suprima 30 boiler.
I've had a problem for a number of years now with heaters occassionally not turning off; even with the thermostat right down and the timer on off, the heaters continue to blaze away. Several engineers have changed bits and bobs but the problem soon reappears. I discovered a 'flush' lever which when slowly turned from left to right finally turns the heating off, I believe this is on the 3 port mid position valve, but not sure really. recently I've only been able to turn the lever half way across, I'm guessing it is jammed with limescale or sludge.
Then last week the hot water system started performing badly with water coming out lukewarm. I had an engineer look at it, he said the top cistern was completely drained and full of sludge - he recommended a power flush which costs £250 - however, before shelling out more cash on this system, has anyone encountered these problems on suprima/boilermate set ups and been able to solve them?
Alessandro
Alessandro
