Science Homework
  • Thread starter Thread starter Shutpa
  • Start date Start date
S
Shutpa
Help.
If 18cm3 of water weighs the same as 24L of steam, what does that tell you about the number of particles in 18cm3 of water and 24 litres of steam
tut tut youve had all the christmas holiday to get it done :roll:
1m3 of water = 1000 litres; you can do the math from that to get how many litres 18cm3 is, surely? :lol:
Help.
If it weighs the same, then the number of particles are the same, so what was the question again? OK it goes to show that steam is a lot more spread out than water.
what does that tell you about the number of particles in 18cm3 of water and 24 litres of steam?
thats either a trick question or a badly phrased one. the number of particles is equal in the water and the steam.
Help.
It only tells me that the 18cm3 of water has the same mass as the 24L of steam and therefore the same number of particles.
It tells me that the number of particles remain the same, but they are spread out (less dense) when heated to 100 degree c at normal atmospheric pressure
Presumably the 24l of steam could be pressurised to make it occupy 18cm3
what happens when you superheat the steam eh?
now then, now then. :lol:
more or less the point, weight will remain the same, clearly, the density will alter according to the pressure of the steam.
what was the point of the question anyway?
actually there never was a point to the question, no question was actually posed.
strange the ways some peoples minds work :?
