I want to get a satellite cable from the LNB down a conduit. It might be a bit of a tight squeeze but I was wondering if a bit of WD40 sprayed on the outer sheathing would help it slide down more easily, or would it attack the cable?
Also when the installer put the original wires in the conduit he pulled them through using some tool which was like a high tensile fishing wire with a weight on the end. He attached end opposite the weight to the end of the cable and then dropped the weight down the conduit and then the person at the other end pulled it through. What is the name of this tool or was it home made? All help appreciated
