Only one cable is needed from the switch, and certainly not 4mm. 2.5mm is enough, probably 1.5 mm OK as well.
It is a ring, the current is shared. 20A is all that is requiredIt's confusing me because it's a 20a switch on a 32a circuit, but this is common no?
No, you will have a 13A fuse in the plug - and anyway the WM will not draw that much.And if there's a single 2.5mm cable from switch to socket that still means this section has a possibility of carrying 32a but via only a single 2.5mm cable - might not withstand it.
If that is so - it's not - then you need a dedicated circuit.There is no fuse on this switch. Comment on the product says it can withstand 4.8kw appliances... well the washer/dryer can go up to 6kw.
Methinks you are getting confused.Me thinks these switches are only for 16a/20a shower/immersion etc circuits.
http://www.screwfix.com/p/british-general-20a-1-gang-double-pole-switch-white/76090
It's confusing me because it's a 20a switch on a 32a circuit, but this is common no?.
Really? FCUs are only 13A and they're allowed and fine.I have never seen it.
We've been there before.I do believe theres a part in the regs which suggests the BS numbers of what can be connected on a ring.
It depends whether you think "Accessories to BS1363 may be supplied through a ring..." means nothing else is allowed to be.
1.5mm is not Ok, unless you use a FCU instead of a 20a Switch.
DS
FGS - why do people keep making this mistake over and over again?It's a spur from a ring final, with a switch fitted. Would you wire a spur in 1.5mm ?
I agree with the loading argument, however regs wise 2.5mm is required.
