TT Eathing
3 Jan 2009
Northamptonshire
Hi All,
I want to provide earthing for a workshop remote from the house and not wanting to export the PME earth I am going for TT. The ground is decent soil but has many stones in it that would make driving rods in it somewhat hit and miss so I thought that I would bury the earth when I trenched out for the services. Would it be OK to use lengths of copper pipe and if so any idea how much would be needed? I would rather over do it than have to provide more later and what would be a good depth?
Thanks in advance for any comments.
Regards,
Dave
Are there any extraneous conductive parts in your out building?
What size supply are you planning on taking out there?
Yes there will be a sink and metal fixed benches. The roof trusses are going to be fabricated out of steel.
I will be feeding it with 16 mm SWA and protecting at the CU with 32 Amp breaker.
Regards,
Dave
So I now have 16mm 3 core SWA in the trench and if I now use the earth to provide an equipotential bond the workshop with the house earth do I still provide a local earth rod/tape? I was just wondering what happens if a workshop socket was used outside as the earth potentials could be different.
Regards,
Dave
Just because you have metal work benches doesn't make them an extraneous conductive part, nor does a sink on its own. Are the pipes feeding the sink metal?
Exactly the same as using a socket from the house.
