Soldering Irons - Ultra fine soldering
23 May 2008
Yorkshire
Does anyone know the best tools for doing ultra fine soldering. Trying to solder components now is starting to feel like performing brain surgery with a spoon! Everywhere I've googled people talk about fine tipped soldering irons. I already have a fine tipped one though and could do with something that is like a needle. I did try a needle for the tip and discovered that unfortunately they don't conduct well at all and won't even melt the solder.
The kind of components I need to be able to solder are e.g the resistors that are tiny squares on fine circuit boards like those on motherboards or PC PCI cards etc... There's a name for these kind of micro components but I can't remember what it is now.
Any advice anyone can give on where to get needle precision tips or how to make one maybe would be really appreciated. I've read that shaving the conventional tips down is a big no-no because you just take the special coatings off and render the tip useless.
We use Weller temperature-controlled irons with a very pointy tip for this purpose. And a good magnifier in front! And set of tweezer types. Good temperature control is essential.
Individual surface mount resistors are not too hard. Things like 208 pin ICs we would tend to run solder round all the edges, joining all the pins together, and then use solder braid to remove the surplus.
Thanks to you both for your tips on this.
If you're finding that surface mount resistors aren't hard then it must be my technique that is bad, probably in part because I'm not using the right kit.
I have a tip just like the one in the link (I've actually got three irons of various fixed wattages!)
I've been finding that the point of the tip doesn't have enough surface area to touch enough of the solder to melt it, but as you mentioned, temperature control is important and it might be that it just isn't getting hot enough.
I think I will be better investing in a proper soldering station with temperature control. A good magnifyer is definitly on my list!!!! I'm my dream scenario my soldering station would have a positionable magnifyer and four claw clamps to hold four corners of circuit boards. I'll check out the Weller stuff, thanks.
SMT - Surface Mount Technology
Not really meant for manual soldering, but you can get specialised equipment because things do need to be repaired.
http://www.antex.co.uk/prodtype.asp?strParents=183&CAT_ID=196&numRecordPosition=1
http://www.google.co.uk/search?q="smt+rework"
You might find a head mounted binocular loupe useful to be able to see what you're doing.
The super fine tips like the copper coloured ones in bas's pictures are hopeless unless you have an RF iron and those SMT rework tips are for rework rather than soldering.
You should be able to solder components down to 0402 with a standard 1mm tip and a good set of tweezers without too much hassle. I can't recommend magnifying glasses though as I've never got on with them and never really needed them.
Just done a search for mounted binocular loupe and followed the links to the SMT stuff. OMG! this is like being in heaven!!!!
Many thanks to you both, this stuff if perfect!!!!!!!!!!!!!!!
I had no idea this stuff even existed. :D :D :D :D :D :D :D :D :D
Forget a conventional soldering iron.
Look for a hot air rework system (although 2nd hand as they are expensive) for proper SMT work.
Components are that damn small these days that as we get older the soldering of them gets harder :D
Also get some fume extraction.
I did electronic rework for 17 years and the solder fumes made my lungs sensitive, so now every time I get a cold it goes to my chest and I cough all the time (it takes about 6 weeks to shake it off!!)
As for the kit, we used the Pace MBT stations with 3 channel digital temperature selection, we generally had an iron, desoldering iron and hot air blower for SMT. We also had a little variable speed drill as a seperate unit for repairing plated through holes and doing multi layer repairs. If I remember we usually had the temp set at just over 400 C for soldering / desoldering and sometimes had to put it up a bit for high temp solder.
Never known Antex products to be hopeless.
Oh - hang on - there is the Pipemaster...
My apologies - never done it - looking at the products and the terminology I assumed "rework" meant manual soldering in the process of repairs...
SMD soldering is not hard as long as you make sure you apply enough flux on surfaces before applying the iron thats the magic key to soldering SMD, I prefer the brush type applicators you may find the pen type better suited to you?
Is the melting temperature of lead free solder higher than the old lead/tin solder? If so, that would explain difficulties when trying to desolder using a conventional iron on newer boards.
Regards
