Recently the pond pump went kaput. So we bought a new one. In the mean time, the wire has been trailing across the decking to the JB on the house wall:
Today I removed the pump cable from this box, and wired it into the UV filter by adding a new gland to it (gland bottom left, pump cable black). I also replaced the terminal block in the unit with a larger one, since I couldn't get both flexes into the old one.
The IP rated box now had a big hole in it, so I replaced it.
Top flex to switch
bottom left to pond
bottom middle to mains
bottom right to lights
It looks a lot neater, I'm sure you'll agree.
Someone will notice there is one less flex in the box than before. There are two floodlights. Both wires ran the same way, so I jointed them at the point of separation:
Clearly there was some slack on one cable, I kept this and coiled it up because that fixture may be moved soon.
Overall view:
By the way, the loads are:
UV: 15w
pump: 55w
lighting: 450w
Its all on an FCU with a 5A fuse installed indoors.
Top flex to switch
bottom left to pond
Overall view:
UV: 15w
pump: 55w
lighting: 450w
