rsj
3 Jul 2007
Ipswich
3800mm span what size rsj should be used taking the sag of a truss on a inner wall of a bungalow if i knocked the wall down the exsisting wall is 100 mm thick?
What about a 150 concrete lintel. lol
Don't sue me if it falls down though
Correct me if I'm wrong, but trusses are self-supporting, so don't normally require a central support.
Otherwise, you need to post more details and the old guy from your neck of the woods can comment
yeah i know but the client wants to store quite of bit of stuff in his loft 8)
Then you need to know how much stuff is going to be stored, so that you don't have a beam just good enough for the trusses
Not only that, picking a truss up if it's not at a node point may cause an issue.
