curved steps
12 Jan 2008
Glasgow
am thinking about building some at the front of the house.
topped with a 600 slab,4 steps high
whats the best way to do this and the best way to cut the slabs in a curved shape?
The best way is to use an engineering brick as a 'nosing' and these can be laid to a moderate curve. The slabs can then be cut as an inset with the bricks acting as the framing.
You can also buy segmented slabs that, when laid together, form differing sized circles. Theses pre-designed sets start with a centre circle and are then surrounded with ever increasing 'rings' with ever lessening radii.
So, you could buy a slab to suit the radius and not need to cut.
I don't like engineers as a nosing (unless they are structural engineers. lol)
Engineers can chip easily, and are too slippery for nosings
Use them for the step, but lay the slab over them to form the nosing
Lay the slab on the top (upside down), and use a block of wood to mark an even profile of the step from underneath. Then cut it with a grinder
I disagree with both these points. A square edged solid blue provides as good if not better purchase than a slab and they do not chip easily. They (solids) can be laid on edge or flat.
I have plenty around my garden and they have had some stick over the years with no chipping and are no more slippery than the slabbed steps at the bottom of the garden.
Sowing a cut edge of a slab looks pants.
Not to mention it's a buggah with the amount of needles that you get through...
