I have bought a wreck to live in, and need to put a heating system in myself as cheaply as possible. The small 3 bed house has a recently fitted Glow Worm 30 CXi combi, but nothing that you could call an effective heating circuit/system. Does my proposed Microbore (yes, I know its not ideal
) layout sound OK? -
Run 22mm copper flow and return pipes 2 metres from the boiler (situated ground floor), then split the flow pipe into two 22mm Speedfit plastic pipes. One of these pipes will go to a 4 outlet flow manifold on the ground floor, and the other to a 4 outlet flow manifold upstairs. Then split the return pipe in the same way, with a return manifold downstairs and one upstairs. (N.B. Each manifold has 4 X 10mm outlets)
The downstairs manifolds will feed 4 small to medium rads. The upstairs manifolds will feed 3 medium rads and a towel rail.
Hope this makes sense. Will it all work? Is there anything else to consider, and do I need a bypass? Many thanks.
