1 gang 2 way 400w dimmer switch
30 Jul 2009
Cheshire
i've connect it up and it works fine except the light is very dim, i'm using a 40w bulb, have tried a 60w bulb and still very dim when turned on full. is the dimmer switch underloaded, do i need to change to a 250w one?
thanks
:roll:
mmmm says check total load of each module is within 60w min to 400w max for 400w dimmers.
i have earth connected in the box which i have now connected to plate, i have 2 red in L1 and 1 red in neutral
I know! The wiring on our house is not what i would call standard even though it is only 10 years old. I have reconnected to the dimmer exactly as i have taken off from the original switch. this is also the case when i have changed other switches in the house to dimmers (which have worked fine for years!)
the terminal you call neutral - what exactly is its designation on the back of the switch???
Common designations are:
L1
L2
COM
C
~ with a / through it
L
A1
A2
None of these are neutral.
You dont have neutrals at a lightswitch in general.
OK thanks for your posts, but going back to the original post any suggestions would be greatly appreciated! :D :D :D
I've connect it up and it works fine except the light is very dim, i'm using a 40w bulb, have tried a 60w bulb and still very dim when turned on full. is the dimmer switch underloaded, do i need to change to a 250w one?
1) Are all the other lights OK?
2) How many lights does the switch control? Just wondering why there are 3 conductors there.
3) This light doesn't have 2-way switching, does it?
All other light are ok, the switch only control 1 light and it is 2 way switching 1 gang. Do you think the dimmer is underloaded?
thanks
:lol:
