Socket outlets for fridge
Wow - are Italian consumer units designed by trendy design houses when they're not busy doing supercars? :shock:
I thought he meant this:
Whatever it is.
Site espresso machine?
A misinterpretation of a spec for a multi-tap transformer?
Actually I suspect it is some kind of site or builders temporary wossname, providing leccy and water....
You plug your appliance into the top if you are working near the distro, but if you are working along way away, then you fill a bucket with electric from the tap, and take it to where you're working.
I'm not sure on using Ceeforms in domestic situations - seem to remember there being a reg about you needing shuttered sockets?
I personally don't see the problem with using a bog standard 3 pin socket as long as it is labelled up as for a specific purpose, as long as any concealed cables are of the type which don't require RCD protection (and the supply is TN of course).
It seems a simple question about availability has stirred up trouble, can I add another possible solution to the original problem. Has anyone seen or used these devices:
http://www.gewiss.com/irj/portal/focusonrestart_IN
and, if so, are they any good.
I see others now do same Automatic recloser for earth leakage protection but at what price the first type were around £350 (not a grand) More here but I have failed to find a price for Merlin Gerin except in euros € 214.95 on sale in Holand.
I also had problems finding price for loads of sites will info but very few with a price.
