Installing a new kitchen. With the fridge being a built in unit and therefore the socket will be near impossible to get at in the future is it acceptable to simply drop a single box down to low level ie so it can be reached from inside the kickboards, and install a flex outlet plate with a single socket fed from the plate. The plate will be switched from a DP switch. Is this the standard way of doing this or what do the rest of you do in this situation? Cheers BL
