how to cut a M3.5 brass screw so it fixes a bleedin socket to a wall?
here's how:-
Have a few consultant engineers decide on the required length and permissable tolerances.
Employ the services of a precision engineering shop to make a mandrel to hold the sodding screw into a lathe with 3 jaw chuck.
Using a parting tool, part off the screw at size plus machining allowance.
Remove cut screw from lathe, send to a cylindrical grinding cell.
Have the cut screw end shoulder ground to size.
get vernier calipers, slip gauges, granite inspection bench in a controlled environment.
Put screw into inspection/standards room.
Allow screw to saturate to local temperature (normally 20 degrees celsius, minimum 12 hours)
Using a Zeiss CMM machine, run a 500 point SPC data gathering programme.
Gauge the surface texture of cut end, 0.6Ra should be appropriate (as a guide)
If no faults found, fill out a certificate of conformity, package screw in bubble wrap. Return to sparky.
Easy !!!
here's how:-
Easy !!!
