I don't beleive a single thing you write
It says London in my profile.I would llike to know exactly where he lives.
I'm contemplating moving to a completelly different area of the uk, but I would like to be assured that I was at least 100 miles away from the hole that he lives in.
what we need is someone who can interject with an even more pedantic view point to really drag this out. Preferably, someone who doesn't reed two good.
Since when has a nut (or heaven forbid a file ) been the correct way to repair a damaged thread!? Get off your horses, get a proper lathe to machine the screws shorter with a square face, then run a die up the damn thread.
134.1.1, anybody?
The best ones aren't just chamfered - they also have a significantly long threadless portion to make it easy to locate the screw in the threaded hole.Mk and decent screws, etc are chamfered at the ends I thought , so they dont damage the wires if they accidently hit them
This is pretty much the only relevant point on the entire topic - no decent engineer would leave a sharp edge on anything metal having cut it. Using a nut doesn't achieve the same effect as a file, so it isn't an alternative.Bans way is good for the thread but dont chamfer the edge.
I use Bans way to cut studding but usually still also file a chamfer.
I thought it was normal for any Metal worker not to leave a sharp end of thread.,
