Hi
I have a shower with a pump (a small box bebeath the bath). It is salamder CT50.
It has 2 pipes going in and then 2 coming out. where they go in and come out they are connected to flexy hose type pipes.
Basically we are not getting any hot, only cold from the shower. The pump is fed from cold from the tank in the loft and hot from the cylinder behind it. the cylinder is fed from the tank in the loft.
I just add that other hot taps in the house are fine so the cylinder is not blocked or anything if that helps.
Why is this happening? Is the pump faulty? Is there anything I can do to check/resolve this problem?
Any help would be great
