End Feed Or Solder Ring.
25 Jun 2003
OK, I'm convinced, I'm doing the kitchen plumbing myself, in the immortal words of Mr R.Hammond just before hitting the start buton on the rocket car "how hard can it be".
So the only decision is - solder ring or end feed fittings.
So with the solder rings I literally apply a nice even heat until I see the "silver ring" appear at the end of the fitting?
It is easy, just follow simple rules, clean the pipe apply flux, heat gently and for end feed apply a little solder, practice on some pieces first, i'm no plumber but have only ever had one problem with soldering and that was due to water still driping through pipe.
