is it legal
29 Feb 2008
Essex
Can a gas safe (corgi)fitter still fit a non- condensing boiler if it is new and in the box.
probably not...put it on eBay and I`ll take a chance @ my own house. Yee Haa :lol:
No. Not unless you pass the criteria for allowing a non condensing boiler to be used under the Part L requitements......and belive me almost non do.
It will have to come out of the box to install it, and you are not allowed to install a non-condensing boiler that has come out of the box.
yes is the answer but you have to meet some criteria which your RGI can asses for you.
if the boiler was shown on a spec sheet or planning drawing approved by building control prior to the rule change, you can legally fit it. This is how all big newbuild sites get away with it,they bought in bulk and the plans were submitted and passed years ago.
lee
If its a wall mounted Room sealed boiler then you certainly won't be able to fit it as you wont satisfy the rquirement for dipensation (this is for awkward installs historically backl boiler units) -but even this has now been overcome with the advent of condensing BBU's :wink:
The regulations say nothing about condensing boilers. All they say is that you have to fit a boiler which has a Sedbuk efficiency of 86% or greater. If the installation meets the exception criterai, it has to be 78% or better.
Now if someone can produce a non-condensing boiler which is 86% efficient ..... :wink:
Baxi are knocking out the Main 24kw se boilers by the lorryload, also Glow worm with the betacom
You can't tell me that they're all getting fitted in 'compliant' installs.
The companies obviously know that, but they're still making and flogging them. I wonder what their position is on warranty calls with a new non compliant installation though.
Do you mean the HE boilers? They are all Sedbuk Band B (86% or better), so can be fitted in any installation without having to meet the exception criteria.
The same applies. They are band B and therefore compliant.
Sorry got confused there, the betacom is as you say a band B. The main 24 is an se though, and like I said they're flogging loads of them.
