Hi Agile
The Boiler is a Vailliant Eco Tech PLus 428
After system had been installed Rad need bleeding every 3 to 4 days. The Magna Clean module sounds as if water is dripping into it! Is this normal and think Boiler engineer said he has bled it.
As far as I am aware there are no problem codes on the boiler though to be honest have not touched it from day it was installed!! Even engineer did not mention any fault codes. Are air lock easy to remove???
