great physics lesson guys but the real issue is that the op's system won't work correctly with a y plan valve in the system
presiselygreat physics lesson guys but the real issue is that the op's system won't work correctly with a y plan valve in the system
utter rubbish!! unless you use a zone valve on each circuit there is nothing to stop the flow being drawn through that circuit when another is running (you would have a similar effect as you get in a gravity hot water circuit)depends on how its plumbed up, you dont need a 2 port valve to control the ufh,
yes and you told him that.
then we had to give a d*ckhead a lesson on 3 port valve workings.
go read how a y plan 3 port valve works.
the grey wire will hold the valve in last position of what ever was last calling for heat.
don't come back till you have read how they work.
Tell him Seco![]()
Close but no cigar![]()
If the cylinder stat is satisfied and the heating shuts off, leaving 240vac on the grey wire the MV will stay in the last position.
Tell him Seco![]()
But if the last call was HW then the valve will stay in HW regardless of the grey wire. So the grey wire does not hold the valve in the last position of whatever last called for heat. It will hold the valve in CH if CH was last to call for heat.
I take it you dont install ufh then! what do you think the actuators are for? on many ufh systems the thermostats control the actuators which (through a relay )switch on the boiler, the 2 port valves are used to block any zones not needed, when a three port valve is used for rads/cylinder a blocking 2 port valve has to be used because 1 of the ports on the 3 port is always open. sheeeeeesh.
I have a three-zone system, one HW, one radiator CH, and one zone underfloor heating (ground floor). The HW and CH are controlled by a 3-way valve, the UFH by a separate 2-way valve. It's all working fine, though was only installed a week or two ago.
