I have a potterton kingfisher MF RSL60 boiler piped with gravity feed hot water and pumped central heating. 99% of the time it runs perfectly, but every month or two (mostly in winter) it will boil over. The boiling seems to happen when the central heating has been running or a while and then the pump turns off. Its difficult to know for sure though because its quite erratic and intermittent.
Someimes we are in the house and hear it. If we are out it will have stopped boiling by itself for some reason (without lockout) by the time we get home, so the only way I know it boiled is because I push a bit of tissue paper up the header tank overflow pipe. We get home and find the paper has been pushed out of the pipe.
When it boils the overheat sensor doesn't lock out for some reason. If I disconnect a wire from the overheat sensor it does lock out - so that appears to work properly.
I've tried changing the temperature sensor and the whole main circuit board but still have the problem. Its difficult to solve because it can't be reproduced on demand. I have to wait a few months to see if it happens again.
Can anyone help me with this problem. I'm starting to think the only thing left is to replace it with another boiler (not potterton).
