Evening Gents, am tidying up some Flow and Return pipes for a customer and access for soldering is a no-go. Any info on using the above fittings? In the past if I've had to use pushfit it's been Hep2o all the way, but i'm keen to try out new materials. Cheers
Other than appearance, I see no advantage of using these over the usual plastic stuff since the innards will be the same and ultimately that's all that matterss
