Conex Cupro push fit
25 Oct 2009
Manchester
Evening Gents, am tidying up some Flow and Return pipes for a customer and access for soldering is a no-go. Any info on using the above fittings? In the past if I've had to use pushfit it's been Hep2o all the way, but i'm keen to try out new materials. Cheers :)
If these are the same as techtite (brass body) they're good but a bit pricey
Yeah there brass body, fittings are a couple of quid a pop :( Do you think they are superior to plastic pfit fittings?
Other than appearance, I see no advantage of using these over the usual plastic stuff since the innards will be the same and ultimately that's all that matterss
might depend where they are going though.. As I've been to a job in the past where a squirrel had chewed through 2 speedfit plastic elbows!
