Sorry to hear all this but he's wrongHe said that no DG company will make windows which are 1 million percent perfect,I have fitted loads of dg windows with no problem.
Agreed!
J
Warm air moisture is getting into your loft therefore needs ventilation to take it out external, needs flow of air, roof tile vents or ridge tile vents or the easiest is soffit vents or air brick vents on external walls if you have it, the more ventilation less condensation, I have ridge tile vents at the top with soffit vents so the air flow from bottom to top. My next door neighbour put in a electric velux skylight window with the vent for condensation and to let in the light in the loft and also open the window on a very hot day!Had to move on from the window prob at the moment as I found condensation in the loft last night![]()
Okay make sure you can see the soffit vents is clearedI have vents the full length of the soffits. I think it may be the insulation which is possibly blocking them.
The ridge tile vent at the top will need cutting out the old mortar joints and replace with the vent type or the easiest would be the tiles vents at the highest level if possible by swapping the tile over with vent type but the roofing felt will have to be cut out carefully and correctly underneath so the air can get out, having said all this you may get away with just by moving the insulation back a bit for better air flow and see how its goesIf I need vents would I just need to get ridge tile vents or would be also be preferrable to put vents further down as well nearer the soffits?
