To stop the Bozo's from guessing!
If anyone else can find an up to date reliable table then please post.
The old edition of Building Regs Part A, 1992 issue, give tables of timber sizes for spans, etc..........You can still find this on the web whereas the newer version keeps it secret, can't see why!
TRADA Span Tables
Yes that's correct Tipper. I've got a .pdf of the latest TRADA span tables so it doesn't really affect me, but the philosophy sucks. Some back scratching gone on down at ODPM / Dept for Communities and Local Govt methinks, so TRADA can pimp the above tables and line their own pockets.
TRADA Span Tables
But just how long will they be there for free access and why change part A to not have the tables that everybody relied upon.
It's the same as for the acoustic requirements for flat conversions, etc, you have to pay to get the official approved designs to some tin pot quango.
I am hoping to convert my loft this Spring. Just a query, my ceiling joists are mainly 4x2, with a couple 4x3 could I coach screw, and glue another 4x2 onto the top of these to form 8x2's? If so, which would be the strongest method, running with the joists or across them? The maximum span is 4.5 mts. Comments appreciated.
Sticking another 4"x2" on top will not satisfy b'regs.
P.s. start a new thread.![]()
I read somewhere that the process of attaching timber onto existing joists is called 'sistering' and this makes up the . I don't know if it is allowed now. I asked an architect recently, who was getting in his 50's and he had never heard of the process so I can't imagine it being very popular. However it cant be much different from 'gluebeams'. It is only my opinion but I think it is possible to achieve a satifactory floor strucure using this method but how you prove the strength is upto the required standard is another matter. Further to that the existing ceiling joists will be too far apart to comply with the standard 400mm ctrs. for 8" or 9" x 2" joists. We need some clever person to take on the building inspector with this method to prove it is not acceptable
Sistering simply means installing another joist along side the existing, then fixing one to the other, with the new joist being deeper, thus carrying the load above without disturbing the ceiling below.
Gluing a joist on top of another joist is not comparable to the 'Glu-Lam' system.
