Hi Everyone
I currently don't have any power to my hob or cooker. My hob power is through a shared 45 and 15 amp socket.
First noticed the problem of the socket not working yesterday and then tried the hob and nothing. So having a read of posts, thought best option would to replace the socket, which I have done. No change.
Tested the Neutral to Live screws for power on the socket and 0 was coming through. So, I thought it must be the fuse not letting any power in.
Looked at all the fuses(all old fuse wire and one cartridge fuse) and all seemed to have wire intact. Tried testing both two of the 30 AMP fuses, there are four in total. Both reported 0 voltage - which I believe is correct?
Didn't check the other two as I didn't notice they were 30 AMP ones. Will do that tomorrow. Plus I am going to replace the fuses with MCB just to ensure I know they are not the problem.
While testing the fuses, I noticed the oven isn't working either - it is on the other side of the kitchen and presumably on a different fuse.
Other than checking the other two fuses and replacing them with MCB's, I don't know what else to do?
I doubt it is appliance failure, as the socket, oven and hob have all gone together.
Any guidance appreciated,
Thanks.
Thanks.
