lee, purely for pump over run. it is how it states in the MI's and would be by far the easiest solution if it came to any warantee work needed.
1. What was your previous boiler?
2. Was the UFH installed when you had your previous boiler?
3. Was the Grundfos 25-55 installed when you had your previous boiler?
4. Did you have any problems when you had the previous boiler?
Has the pump impeller been inspected yet?
It may well be undersized but the 25-55 will perform a lot differently in relation to the Grundfos curve graph due to the installation of a secondary pump on this system.
Also the UFH output estimation given earlier is wrong and much too high.
So a lot of wrong numbers here IMO.
As D Hailsham suggested earlier the Index circuit should be calculated accurately to give a better picture.
I would fit the pump on the return to the boiler instead of the flow thus raising the inlet pressure to the pump.
Apart from your bit about pump impeller your still ignoring the point that this all worked fine prior to adding a boiler with 20-30KPa greater resistence.![]()
The main circulator has this noise but also you can hear what flowing through it,a bit like when your turn a tap on with an empty hose connected to it, you hear water flowing through the hose until it starts spurting out the end.
