problem when changing switch
you are correct it was a double pole switch, however in the new switch the lights are not working, i have put a meter on the wire terminals to measure the current but there is nothing comin from either of thm :oops:
Set your meter to ~V or VAC. It sounds like you are trying to measure the current between two conductors. You need to measure the voltage. :wink:
Or is this what you mean? Which conductors are you measuring between?
You shouldn't really do that - a multimeter set to a current range will have a very low resistance, so if you happen to connect it wrongly you could get a big bang and a wrecked meter.
And it's pointless anyway - why do you need to know the value of the current flowing? You should be able to do any checks you need by measuring voltage and resistance.
