What about steel capping? If it can be properly earthed, would that fulfill the requirements for nonRCD concealed cables?
no it would not.. it has to surround the cable on all sides, including the side facing the wall.. you even say so yourself in the next post you made..
In what way would it not comply? The cables would be surrounded by an earthed metallic covering....
see?
I think I might just do away with cabling completely and fabricate a bussbar system from copper pipe.![]()
wouldn't that be nice, a 3 bar busbar chamber set at 450 from the floor.. you'd just have to clip in your sockets where you want them..
hmmm, singles in copper pipe = MICC equivalent...If you want to use copper to provide your earthed metallic covering then install MICC....
