Hi all I know there are a lot of questions already regarding this kind of install but most differ in some way
Quick specs:
single oven 2.8-3kw
ceramic hob 6kw
standard 3a extractor hood
Grade of cable - 6mm2
Distance 15 m max
40A MCB at CU
My questions are exactly how i can do the wiring from the oven FCU (which i hope to have in a wall cabinet, should this be a 45A FCU or a 32? screwfix only seem to do 20A or 45A
) to feed the oven hob and hood using additional FCUs that's the neatest 'best practice' way of doing it
What i would like is to have all the fused spurs under the worktop behind cabinets as they shouldn't need to be very accessible
Oh as a final consideration the oven comes with a 13A plug on it so it could be fed from a socket but it can also be hard wired, is there an advantage to either way? I would probably sooner do a socket for it
Thanks in advance to anyone willing to help!
Quick specs:
single oven 2.8-3kw
ceramic hob 6kw
Distance 15 m max
40A MCB at CU
