What are my chances of being able to pull Cat5 thru mains
12 Jan 2010
Cheshire
I would like to install a Home Automation system, (CBUS) but will need to run Cat5 to the light switches. Most of this will be a retrofit, and I really don't want to have to redecorate.
So I was wondering has anyone pulled cat 5 through existing mains cable.
I'm guessing this is not possible, but it will make life a lot easier it it is.
The existing cable is twin and earth chased into the plaster.
what I'm wondering is...
Can I pull the live & neutral conductors out of the wall from above leaving the outer insulation in place, and pull some cat5 through it ?
You mean the existing cables are not in conduit, and you want to use the inner cores as a draw wire to pull cat 5 cables through the sheath?
It'll never work.
4
Why not use an ethernet over mains type system, then branch from the electrics into a socket? That way you'll be able to use your existing electric cabling to run network traffic too.
Like this:
http://www.itreviews.co.uk/hardware/h2114.htm
Absolutely no chance... sorry.
Like this:
http://www.itreviews.co.uk/hardware/h2114.htm[/QUOTE]
I suspect that this will be too costly due to the number required.
Put the cat5 in onece and for-all.
Frank
Like this:
Frank
Actually, I suspect it would be completely useless because we're talking about C-BUS, which despite using cat5 cable, is not the same as ethernet.
It's not for TCP/IP ethernet - It is for a C-Bus.
I am afraid you are going to have to chase the walls if no conduit is in place - When you do, make sure you fit a piece of 20mm conduit or larger for when the next home owner strips out what you have put in......
Not a hope in hell. If the cables are not in conduit then you're screwed.
Thanks for the advice everyone.
I think I knew as soon as I'd typed my question in that it was a bad idea, but I thought it was worth asking just in case.
So it'll have to be back to the drawing board.
