Applying sealant to old felt roof
6 Jul 2010
Sussex
Hi all,
I have a bungalow with flat roofed porch with the usual felt and stone chippings on top.
I am now getting a slow wet patch on an inside room in the area where the porch roof meets the pitched roof line of the bungalow. The rafter in the same area is also getting wet.
I've had a look at the felt and its looks OK - no noticeable gaps, bubbles, cracking etc.
I plan on covering the felt and felt joints in that area with Flexacryl or similar to see if that stops the seepage.
Am I OK to just scoop away the chippings and brush the area to get rid of loose dirt before painting on the sealant or will any dirt at all prevent the sealant from doing its job?
East Sussex - ? . I can recommend a good and trusted roofer :wink: No relation to me - (tho` I know a plasterer who is ).
In that case go for Wickes ` bitumen - cheap as chips :wink: . works as well - just looks er, black
Be lucky for that to do any good,it may ,it may not but best case scenario=short term,very short.If you dont have the money and want the water to stop,to prevent further damage invest in a tauparlin(less than a tenner) wont look nice but WILL stop the water ingress while you save up.If its joined onto your house tuck sheet under cap flashing and weigh down and nail edges(lath/nails).Lying laths on the roof weighed down with bags of sand would do.If free standing,no probs just secure edges with nails/laths but dont put nails through sheet on roof area into decking.
