Replacing a ceiling rose with a downlighter
10 Jun 2010
Oxfordshire
Quick question - does this work fall within Part P?
And is it acceptable to transfer the wiring from the ceiling rose into a suitable junction box (5A or 20A) in the ceiling void which will then feed the downlighter?
Steve
It's outside part P, but it does need to be accessable.
The norm is to replace the rose with choc box and connectors, that should then reside inside the cup element of the lamp fitting or be placed in the ceiling in such away that it can be pulled out for inspection when the lamp fitting is removed.
See wiki for terminations- look at UK electric- lights
Part P applies to all domestic electrical work.
Whether it is notifiable depends on where this light is. Will it be in a kitchen or bathroom?
Unless the room is tiny, replacing a ceiling rose with a single downlighter will make the room rather dark.
You know it does:
This is Part P:
Err......
I'm absolutely aware of the need for an electrician to be fully involved with this project.
Ban All Sheds
Bloody Hell - do you read every thread! :D
This isn't for my house at all. A friend from work has got a ceiling rose with light hanging down in the hallway of her flat.
I've not seen it but apparently it's so close to the front door that the door catches it every time it's opened.
She bought a downlight a while ago and asked if I knew anyone who could fit it.
So, I thought I would check to see whether I am ok to fit this myself since it's not in a notifiable zone like the kitchen and is simply replacing one type of light fitting with another.
But I still wanted to check the best way of doing it.
Happy with my justification
As for my own project- still trying to find a local electrician
Steve
Vetinary, make sure you have the correct IP rating if this is going into a flat. Fire retardation needs to be considered. Sorry i know thats not the right word but you know what i mean.
It would be a lot easier if she got a low-profile surface light fitting.
Something like this
That could go in the same location as the pendant.
The door surely does not go right up to the ceiling!
Thanks guys
I found the piece about fire retardation in the Wiki - I am going to tell her it's beyond my remit if she wants a downlighter, but show her the other suggestion, which I certainly could do
Cheers
Steve
