I think the reason boiler manufacturers want to tie you into product lines is that the controls manufacturers know the domestic market installer just do not want to or can combine different brands. WC is great and using one manufacturer is undoubtedly simpler.
I’m just starting to investigate the Honeywell Smile range which is opentherm and seems the closest I can find to what I want. The base system will do two zones, DHW, optimum start/stop and compensated flow as I understand. You’re not tied into the electronics of the boiler as the control unit keeps the boiler flow temp as low as possible by turning the thing off at the lowest suitable temp itself. Just got the info today and it does seem intimidating but manageable though maybe overkill for anything under 5/6 bedrooms; oh for the self-learning AQ6000.
I’m with D.H. on zoning. If you turn off sections of the house you simply create different areas of heat loss.
Don’t want to get into an argument with looney but the potential monetary savings possible in a standard house when balanced against living in comfort level for the occupants in my mind do not make the effort, cost and duplication of pipework involved when zoning worthwhile.
