Bosch multi-cutter vs Fein MultiMaster
Bosch all the way, the blades are cheaper but no worse, the cordlessness is good, I've got one and it's fantastic, use it almost every day. It's a bit power-hungry, if you're using it heavily you'll need three batteries, but that's my only criticism of it, and it's not really a criticism as the power is useful. Not quite as powerful as the Fein (I've used them side-by-side) but does the job.
Get the kit with the accessories if you can find it, there's loads in there and it's much cheaper than buying them individually, blades are cheaper that Fein but still around £6-£10 each
the new bosch blue Mains GOP will be out any day now
also a adaptor so you can fit bosch blades to fein machines :lol: plus a few new blades
had the gop about a year now fantastic tool
latest job was fitting a tv hifi made from pine and looking along the lines off a traditional welsh dresser
had to cut out a square to allow the light switch through
then when it was fully loaded with tv and all the gagdets wired in had to cut a slot in the skirting and remove a corner off the cabinet for the wires you couldnt do those easily any other way with such resticted access
Aminster have them for £99
http://www.axminster.co.uk/bosch-bosch-gop-250-ce-multi-cutter-prod833182/
What are they like to work with? How easily do they deal with plunge cuts in skirtings etc, whats the vibration, accuracy like?
I too have never had the chance to play with one and guess I really could do with one.
I don't care too much about price and don't necessarily need cordless but could you explain in detail the differences between the Bosch and fein. By the way i would never use it for delta sanding, I have a Festool DX93 for that.
On the 10th October, Aldi have one of these for £40 with 24 accessories
my answer to a thread on another forum so some links wont make sense
argos have there own version and sell 4 bosch blades to fit
http://www.argos.co.uk/static/Product/partNumber/7113347/Trail/searchtext>MULTI+TOOL.htm
12v overpriced in my oppinion 1 battery with 3 hr charge useless
http://www.argos.co.uk/static/Produ...text>MULTI+TOOL.htm#pdpFullProductInformation
bosch 10.8 about £170 2 batteries 40 min charge with all the tools which cost around £90 when bought individualy
http://www.axminster.co.uk/bosch-bo...h-36-accessories-in-systainer-kit-prod797263/
or the new blue version off the 180e
http://www.axminster.co.uk/bosch-bosch-gop-250-ce-multi-cutter-prod833182/[/QUOTE]
Cant see a problem with the cost of blades for either the Bosch machine or Fein multimaster when you can get perfectly good blades on ebay for roughly £4 a piece. IM NOT AFFILIATED TO SHARK BLADES but I have now used a number of their blades from ebay and it has made my Fein machine a necessity not a luxury. Hope this helps :)
link please :D
DAMN they're cheap! :D
the new By the way i would never use it for delta sanding, I have a Festool DX93 for that.
The cheapest I can find that sander for on Froogle is £189.
It's 150W, which is the same as a cheapest it can get no name delta.
Are they worth that, and if so, why?
Festool worry me, as they sell normal tape measures for £14. Yikes!
The bosch is good no issues
For hard graft the fein supacut (industrial version).
Use the bosch most of the time just so handy, fein with diamond blades for hard work cutting tiles grout etc etc
They are at Aldi tomorrow (20th October) not 100% sure of the make but the blurb I saw said they came with a 3 year warranty. From the picture it looks a lot like this one they sell in Machine Mart
http://www.machinemart.co.uk/shop/product/details/multifunction-grinder?da=1&TC=RV-060514180
They work ok but you'll need some ear plugs in when you use them :(
The GOP 250 CE is much quieter in comparison.
