Hi, I have an elederly neighbour who asked me if I could have a look at his electric shower, as it has stopped working, and he has trouble geting in and out of the bath.
Since this guy is a good neighbour and a nice guy I said I would. I went round the other day and the first thing I checked was the neon light on the pullcord switch, working ok.
No chance his pipe is frozen as his house is very warm. So I Isolate at the fuse box, Which is very old plug in type and find he has a 30amp fuse protecting the shower cable.
Then remove the shower casing and check for power, all ok. I then check for power at the terminals inside the shower after replacing the fuse, all ok, So the shower is faulty.
So we go to b&Q and get a new shower unit and a 45 amp plug in mcb, I also tell him it should have an rcd fitted. Couldn't get one at the shed, so Just did what I could at the time.
When I took the shower unit off the wall i found live and neutral had been rubbing togethr to the point they had both worn right through. and the back of the unit was burnt.
Then When I looked more closely at the shower switch I find it has a hole burnt right through it.
Now I am capable of sorting this mess out for the guy, even replacing the cable as I suspect is probably damaged, and doing a good job. He would pay for the materials and I wouldn't charge him for my time,
as I said he is a good neighbour and doesn't have much money. Should I do this job ? Or should I tell him he needs to get an electrician in, bearing in mind he probably won't do as he wont be able to afford it.
Sorry for the long post guys, but It's a bit of a moral dilemma for me.
