Chasing out for the electrics in my kitchen above the work surfaces to keep costs down before electrician comes in January to put in new ring and have hit a problem in the shape of a small window.
To keep the runs in the safe zones im cutting the chase so the cable will run straight out of the side of one back box into the side of the next.
However i have a small window directly between two of the sockets which would require the cable to be run down about 5 inches and around the bottom of the window and back up 5 inches to continue the line to the side of next socket.
The floor is concrete so i cant go down and under floor boards and i cant go up as i have another small window. If i were to go under around the window will that be acceptable , if not could it be made acceptable with the appropiate conduite. He was going to run cable in white plastic looking stuff
I've tried calling electrician but he is on his christmas holidays.
