Hi All - Due to a cracked Heat Exchanger I am having to consider a boiler replacement
My house is a reasonably large detached 1930s construction with a 1970s single storey extension. My boiler is currently a Baxi Solo 2 80 PF and it supplies a total of 13 double radiators (including two 1200mm doubles) and a standard vented HW cylinder for the water. The house was extensively replumbed about 15 years ago to accomodate full CH. The boiler is located in the roof space of the extension right at the gable end wall and is vented directly through an 18" flue.
My concern is that I will be be forced into extensive replumbing to accomodate a combi boiler when all I really want is a simple replacement boiler that utilised the existing pipework as far as possible (including a 15mm gas feed) - Will the part L regulations allow me to do this? (There is no other space available in the house)
and what replacement boiler would you all recommend?
Does anybody work in the Corby area that fancies giving me a quote?
