I
ironman1
As far of my best knowledge so far the calculator shows that the output needed is around 8kW and as you said when I deduct the 2kW for combi boiler ended up with 6kW.
Either check your calculations or forget the reference source your using............6KW (20,470 btu) for a 2 up 2 down is nowhere near enough heat load...........be freezing your cods off come cold weather...............@ least 10 KW heat load.................mears calculator would argue the point.
