Trowel marks
  • Thread starter Thread starter marsaday
  • Start date Start date
M
marsaday
I have a normal steel trowel for plastering (£7 approx), so not a posh marshaltown etc.
I noticed the trowel is leaving one fine line when i go on an upwards sweep, but nothing if used the other way.
I could not see any grit on the trowel so assume there is a blemish in the metal.
Can i sort this problem out ? Do you use sand paper to rub the trowel down to get rid of any contanimation.
A Marshaltown trowel is not a posh trowel!! It's a very expensive trowel, and it's probably the name you're paying for. In the forty odd years i've been plastering, i've never owned one. It's always been a "Tyzack" for me,  8) plus i also have a Ragni,,, everyone has their own preference. The thing to remember in plastering is, it's the ability of the plasterer himself. You can own/use the most expensive trowel in the world, but if you're not a good plasterer, it'll never give you a good finish.
Anyway,, sorry for rambling on a bit Marsy,, if you're planning to be a plasterer, do as Roy says and get a better quality trowel, £15, £20 upwards, rather than the cheaper £7 quid ones. Check the trowel before you buy it too,,,,,, look along it for straightness, and across the toe and heel,,, check along the edges, (carefully) for any bad nicks etc,, make sure the handle is secure. Enjoy the trade. :wink:
I think an emery cloth or oil stone is a recommended way of tidying them up
You're right Newbee.
Sometimes, you can hardly feel/see these little nicks on the trowel edge,, but the line they leave in the plaster is very noticeable. The finely honed edge of a trowel is very delicate, and it doesn't take much to damage it.
Thanks for info.
I am doing my own attic, so this is not for a living.
I will try and rub it down a little and see how that gets on.
I dont do it for a living either, well, not normally, although if your doing a job you need good tools, especially as in comparison a trowel is quite cheap.
