- Joined
- 11 Jan 2004
- Messages
- 46,883
- Reaction score
- 3,987
- Country
Hang on mods, before you move this to software, bear with me.
I've been having trouble attempting to load Ubuntu.
Yes, yes, I know you've all nagged at me before to get rid of my archaic hardware
, but I'm enjoying tinkering with it and hope to learn some stuff along the way.
I still have this old AMD XP2000+ PC with 80GB HDD and 256 RAM. It used to have Win ME then I DBAN'd it and installed Win XP SP2.
I have DBAN'd the HDD again, then attempted loading Ubuntu 10.10 from an official disk I was posted. I know it works, as I've loaded it onto another PC.
I get so far into the install process, then the system hangs. I've retried it many times and it can hang in several different places, so it's not consistent.
The software demands a min of 4GB free (no worries there) and 256 RAM. The actual DIMM is 262, so that's OK.
So, I'm beginning to think there's a hardware issue. I did swap the HDD for another I know works, so that hopefully eliminates the HDD. So, could the old AMD chip or the limited memory be holding it back?
AFAICT, the chip should be compatible, so that (to my logic anyhow) leaves the RAM.
Do you think increasing the RAM will help? Is it hanging or is it just incredibly slow?
If you think the RAM is an issue, could you help me identify the modules I need please?
I'm fairly au fait with PC stuff, but I find the huge array of memory modules available totally bewildering.
The machine has an MSI KT4V MS6712 MB, Version 10A (1996).
The current module says simply: DDR400 (2.5) 256.
The 2.5 I guess is the supply voltage. Many modules I've looked up are 2.6V. Is this crucial (excuse the terrible pun!)?
The other thing is, looking up that MB on MSI's site ( http://www.msi.com/product/mb/KT4V---KT4V-L--v1-0-.html#?div=Detail ), they say that DDR 400 is only compatible with a certain CPU FSB speed and then only certain modules are guaranteed to perform correctly.
Could my PC have originally been fitted with the wrong memory module?
If so, this would explain why it has never performed smoothly.
Can you help me please?
