narrow width radiator
21 Apr 2011
Oxford
Can anyone recommend a good make narrow width radiator or towel rail, ideally 350mm, or less that doesn't stick out too far from the wall, but has a decent heat output to warm up a bathroom?
contradiction in terms there :D
need to know the w/d/h and whether its well insulated
we also need to know how many outside walls and iff the roof is ouside
The bathroom is approximately 2m x2m x2m. One window, one outside wall. Dunno about insulation. Had calculated that I would need ~500 watt or above.
purmo rads tend to be very narrow to the wall. I tend to use them when i need a double in a hallway or something. Not sure about towel rail though they always tend to sit off the wall a fair bit so you can get your towels on them, otherwise would be a bit pointless !
Thanks, from a fellow Spurs fan :)
and when you put a towel on it no heat gets to the bathroom, the clue is in the name for these things, i cannot understand why people fit a 300w towel rail in a bathroom then moan the room isnt warm enough when they took out a 600x 500 k2 rad whick gives out over 1kw of heat
...................if you can fit a towel on a 300mm wide rad/warmer. :shock:
think you'll struggle to find something so short in width. I know plumbfix/screwfix do some designer rads which are 300mm wide but very tall. Not for towels though.
Thanks. Have searched online. Featureraditors have some 1200 x300 towel rails.
