No, it's not. In fact, quite the contrary, the accelerator resistor speeds up the thermostat's response rather than slowing it down.Al the biasing resistor does is adds a bit of ambient heat so that the thermostat is immune to cold drafts from clicking it on and off constantly. Now I have not delved too deep into this so perhaps someone in the know could confirm this is the case
Current flows through the resistor when the thermostat calls for heat, so it gets warmed by both the room air and the heat from the resistor. It reaches the set temperature more rapidly than if the 'stat relied on the room air temperature alone. This corrects for the room heater warming up the room air more quickly than the thermostat's bimetal sensor can respond.
Electronic thermostats have a sensing element that has a much lower thermal mass and thus do not require accelerator heaters.
