Hi forum users,
After having conservatory built on back of house we have had 1st fix of electrics installed, had to have a new up to date fuse box installed by same sparky as we had the old style. That's all in and working, he said once in he will do tests, it's come back saying we have a dodgy plug somewhere, he has given us the option of either a days labour charge or to charge per plug. If he found the faulty plug at the beginning I'm quids in, however if it was the last plug it will cost an arm and a leg. He spoke to my wife about this as I was at work but said only way of finding fault was to remove each socket and check wiring??!! Surely a plug socket tester is easier solution??
Any thoughts from you ppl??
Also he said my mains water is not earthed nor the boiler so is quoting to do that, is this important to be done?
Just don't want to be ripped off!!
Sparky has said once work is completed a certificate will be issued.
Many thanks for reading my post query..
