Good advice from Alarm. Especially if the DNO fit the check meter as they will have to then explain why their two meters disagree with each other.
Stupid advice from GayOwl as two wrongs do not make a right and you would be guilty of causing criminal damage with intent. Very easy to prove in court that you were guilty and you would be convicted. It might also lead the disreputable builders to take revenge on you.
