I am currently modernising a house. Though the house is 1950s the electrics in there aren't "too bad" (my opinion based on no experience!).
It has a modern consumer unit but the older wire colours. We're re-decorating each room at a time and I was wondering what I could get away with under Part P work that need not be notified. I think the document I've read from Panning Portal leaves some wiggle room for interpetation.
The first room we're looking to decorate is a bedroom. We're looking at changing all of the existing socket fronts and spurring off one to add another socket high on the wall for a wall hung TV. While the room was empty and gutted I was going to rewire the legs between the sockets with new grey/blue 2.5 cable but won't bother if this constitutes notification.
Assuming that this doesn't and that it's ok, could this be taken further till eventually the whole ring is re-wired bar the legs back the CU all exempt from notification? I think if I were to do as one piece of work my interpretation is that it would need notification. But if I do it in bits and pieces I wonder if it's considered ok.
Interestingly the Table 1 only mentions replacing cable for a single circuit where damaged by fire, rodent or impact. It doesn't mention replacing it for the sake of it. In this case would damaging the cable of each leg before I replace it allow me exemption form notification?
I will still have the legs back the CU which I don't think can be done without notification but I can get a spark in for a day to do that and a bunch of other things in one go and he'll self-certify?
Thanks for any advice.
