timesaver strap on boss
29 Mar 2009
Hertfordshire
Hi Chaps,
I need to cut out a 64mm hole in a timesaver down pipe to fit a strap on boss. I have the boss etc I just need some advice on drilling out the hole. I have a bosch bi metal holesaw which I have previously used to cut holes in structural steel joists. See link below.
http://www.google.co.uk/imgres?q=bo...&tbnw=166&start=0&ndsp=21&ved=1t:429,r:12,s:0
Has anyone tried this with this holesaw and has it worked? Any advice appreciated.
Plastic downpipe? In which case you're laughing, just make sure you use a very low speed, e.g. a cordless drill on its lowest gear and with just enough pressure on the trigger to do the job. Presume your holesaw has a pilot drill centrally?
Cast iron is a different matter, of course!
The biometal holesaw should do the trick, but if not stitch drill around the marked area you want to cut out and use a sharp cold chisel & lump hammer.
bi metal yer scotch twonk :roll:
Bi metal or bisexual, whatever lights yer candle luv!!
You know what Kev, I think I've drank that much Single Malt I've turned into Scotch. Pass on my regards to your wife/sister........... :lol:
