Thanks john, im now with you, i think, your talking more regarding the direction of the in and outs of each switch, whereas i was discounting the actual internal switching positions
and meaning regardless of whether flowing via the switch or through the link wiring
And even if you took the guts out of the mechanism.
But i agree on your last point , also as you showed earlier in normal two wire strappers , the switchline is always found in the "common" terminal and the Live feed would have to toggle between L1 and L2
We all know its irevolant on 1 way switching most of the time, anyway
Goodnight
The Live terminal and the switchline terminal never ever changes over except with an intermediateChange to the alternate wiring method and which terminals are live feeds to the switch and which are live outputs depends entirely upon which way round the switches are set and changes as the switches are moved.
Goodnight
